Subject: Report Module hide no results display
borntosucceed
11 Jul 2009 12:58 AM
Hi;
I would like to use the Report module to overcome a shortcoming in the article module from ZDNN. Commenting does not support that the user can specifiy a URL like it is very often done in blogs.
My workaround is to use Dynamic Forms for users to enter their comments and store this in my own table. The idea then was using the report module to display the comments for the article. I could easily format that nicely with the XLS Visualizer, unfortunately when there is no comment it displays the message "The report query returned no results", which does not look good.
Do you know if this can be hidden or can you recommend another module that can do the job?
Thomas
borntosucceed
11 Jul 2009 5:18 AM
I actually found out the message is only displayed for the host user, which is good, but I have another problem now, as I need to pass a querystring value to the SQL that I want to run and to my knowledge I cannot do this with the report module. So if anyone knows a module that I could use instead please reply to this post.
11 Jul 2009 8:36 AM
I've recently discovered SQL Grid Selected View (SGSV) from Tressleworks.ca.  It's not free, but it is so inexpensive that you can consider it free.  It provides all sorts of options for reporting results from database tables.  It can take query string variable and session variable as inputs.
There is also a free version that you can use for evaluation - an older version of the module.  I recommend spending the few dollars and going to the current version.
Forums > DotNetNuke® > Modules > Report Module hide no results display
RE: How to close a website while you are working on it by mcmanta
Hey JoeThanks for the quick reply I will give that a try.best regardsTom
Good Morning - and Thanks Lee! I did send the upload error message to DataSprings as well, but ...
RE: Google Verification Code Question by BCRose
I found the solution. If anyone else wants to know this information you must go to your home page ...
Where do I place the Google verification code?I have been searching this site but cannot find any re...
Thanks Lee...I have been watching the videos. Lot's to learn here.
Start with:Setup Preparations for SkinningIntroduction to SkinningThen move on to some of the other ...
RE: How to close a website while you are working on it by jncraig
One way would be to assign two URLs -- a public URL and a private URL. Some hosting services provid...
RE: How to do links? by jncraig
There is a links module. If it has not been installed (and many modules are not installed by defaul...
RE: How to install DotNetNuke to Windows 7 - Issue 51 by jncraig
You need to purchase a subscription to DNNCreative Magazine.
RE: How to install DotNetNuke to Windows 7 - Issue 51 by jeihouni
hi,how can i download this video?is it free or i should pay for that?
RE: Enhancing the OWS Login Module and Building a Twitter Module - Issue 54 by bizcomit
How can I change the module/config to log-in using Enter Key ?
RE: DataSprings / Aweber by leesykes
Hello,When I created the tutorial for Aweber, the code they provided was placed within Form tags. An...
How to do links? by Guy..L
