Subject: How to Create Module :
hassangas2003
04 Jul 2009 1:57 AM
this first my question in aforum,i'm abeginer in DNN,I have web user control already used to old project and now i need to add this web user control to  DNN 5,please all,how to added.
and plz how to Create new Module directly in DNN v.5???
this my try to do that:
1- New file and select DotNetNuke Dynamic Module.
2- Rename module(APP_CODE,DesktopModules)
I KNOW THIS SIMPLE TRY>>>>
PLAESE ALL HELP ME>
PLEASE STEP BY STEP
IAM WAITTING..............
thaunks,
hassan
04 Jul 2009 7:10 AM
I'd recommend the book on DotNetNuke module development by Mitchel Sellers, and also adefwebserver.com. There is a module development guide there.
Germaine
09 Jul 2009 11:40 PM
Hi Hussan,
My understanding is that you already have a existing web page (with all the functions/codings), you want to copy this into DNN 5.1? Is that what you trying to say?
Forums > DotNetNuke® > Modules > How to Create Module :
Glad it's working!
Firefox SWF file by ce221
PayFlow Link by murphydolores
RE: Send email with Dynamic Forms Results by jesp17
Hi Lee,I've asked DataSprings if there is a way to solve my problem (wish). Here is a reaction:I don...
Background Music by kparker
Do you know of any module that I can use to play background music on a single page?  Or do you have ...
I did this several years ago, so I think that what I found must have been in the "Professional DotNe...
