Subject: Module Wrapper & Tab Aggregator??
gbrown
03 Jul 2009 2:47 PM
Has anybody tried to place a Module Wrapper module from ZLDNN inside a Tab Aggregator module from DNNStuff??
Looking for a solution to place modules side-by-side inside of a tab in Tab Aggregator.
Greg
gbrown
03 Jul 2009 6:42 PM
Found the Ajax Module Wrapper from Gumbosoft. Bought it and tried it - it works inside of Tab Aggregator.
Greg
05 Jul 2009 3:47 AM
ok great, thanks for letting us know
Forums > DotNetNuke® > Modules > Module Wrapper & Tab Aggregator??
RE: How to close a website while you are working on it by mcmanta
Hey JoeThanks for the quick reply I will give that a try.best regardsTom
Good Morning - and Thanks Lee! I did send the upload error message to DataSprings as well, but ...
RE: Google Verification Code Question by BCRose
I found the solution. If anyone else wants to know this information you must go to your home page ...
Where do I place the Google verification code?I have been searching this site but cannot find any re...
Thanks Lee...I have been watching the videos. Lot's to learn here.
Start with:Setup Preparations for SkinningIntroduction to SkinningThen move on to some of the other ...
RE: How to close a website while you are working on it by jncraig
One way would be to assign two URLs -- a public URL and a private URL. Some hosting services provid...
RE: How to do links? by jncraig
There is a links module. If it has not been installed (and many modules are not installed by defaul...
RE: How to install DotNetNuke to Windows 7 - Issue 51 by jncraig
You need to purchase a subscription to DNNCreative Magazine.
RE: How to install DotNetNuke to Windows 7 - Issue 51 by jeihouni
hi,how can i download this video?is it free or i should pay for that?
RE: Enhancing the OWS Login Module and Building a Twitter Module - Issue 54 by bizcomit
How can I change the module/config to log-in using Enter Key ?
RE: DataSprings / Aweber by leesykes
Hello,When I created the tutorial for Aweber, the code they provided was placed within Form tags. An...
How to do links? by Guy..L
