Subject: Can I modify the Default Events module only for a Portal?
pete
03 Jul 2009 4:44 AM
Dear Colleagues,
I manage a site, which is a portal in a larger dotnetnuke environment with several portals. I want to format the way data is displayed in the events module page, but the site manager tells me that if we modify the events aspx files, it will affect the whole site, including users of other portals who have used the events module. What can I do?
Thank you and regards.
P
03 Jul 2009 10:26 AM
If you create a skin for your site, it will apply only to your site.  Also, portal.css applies only to your site.
The trick here is to change the styling via CSS, not by modifying aspx files.
pete
07 Jul 2009 6:27 AM
Dear Craig,
Thank you very much for taking your time to explain. I guess I was not clear, but what I actually wanted to achieve is to format the display aspects/elements/fields etc which is on the aspx files. But the problem is the admin could not grant me access to the files in the server and asked me to see whether i can have a diff module which he could install as a separate one.
07 Jul 2009 7:13 AM
I was under the impression that the current version of the Events module supported templates for display.  If that's correct, you can create custom templates.  You may need to ask the admin to install the templates for you.
If you cannot use templates and CSS to achieve the look that you need, you will have to create a custom version of the Events module.  You can do this from the source version.  I would suggest that your custom module use a separate name to distinquish it from the unmodified version.  You appropriately named and packaged version can be installed (you'll need the admin to do that part), but you can then use it separately from the "regular" Events module.
Forums > DotNetNuke® > Modules > Can I modify the Default Events module only for a Portal?
Localizing Skins and css dynamically based on language selected by sadabahar83
Hi, I want to dynamically assign a skin and CSS based on the language selected. Different pag...
Recomended DNN version? by lolorn
What version of DNN would be recommended for creating a new site? Has DNN 5.2 turned out to be as st...
query regarding page options by kaustav_kar
Hi,My site will have two Home pages, one for a new visitor and one for a returning visitor.   Is the...
RE: Plz Help. Page_Load_Exception by zaidkhan
URL of My website is www.pafkiet.edu.pk
Few new skins by Rozo
Skins for DNN and other CMS. www.stelg.com
RE: Plz Help. Page_Load_Exception by jncraig
Can you provide a URL?
RE: Custom Textbox Size by jncraig
For the second part, you can switch the editor to source mode and enter unstyled text. For the fi...
RE: Picture size limits by jncraig
The little red x's generally mean that the link to the image is broken.  My guess is that you have a...
RE: Uploading an MP3 file to my website by jncraig
web.config is in the root directory of your DotNetNuke installation.  ALWAYS (!!) make a backup copy...
RE: Customizing registration page by kana
Picture size limits by Doug_s
I'm lost - I've just changed host and a few thing that used to work don't, plus I can't display anyt...
RE: How to Limit Access to Administrator Modules in DotNetNuke 5 - issue 50 by samjst
Hi, Did you manage to solve the problem? I'm facing the same issue: users with access to add and...
Ealo Tab Localization help by sadabahar83
hi, I have installed Ealo Core Api and Ealo tab localization and ealo Menu provider. menu is wor...
Custom Textbox Size by PopeOMalley
Hello everyone,Do you know if there is a way to customize the size of a textbox control on the Manag...
RE: DotNetMushroom RAD by md-pv
That sounds interessting too. I'll check it. Thanks a lot.
thanks alot for replying Sir,Well.. my Under Construction Redirect issues are more general and they ...
RE: Uploading an MP3 file to my website by billkidwell
Joseph - I added the mp3 extenison to the list. It still diod not work. No error message but it did ...
Two things could go wrong.First, mp3 might not be an allowed file type.  You should have received an...
Joseph - Thanks, but I see my post was unclear. I tried to upload the MP3 and teh uplaod failed. No ...
RE: What are best tools for localization? by jncraig
The modules from Apollo and the EALO and Magic Content modules are the ones that I would use.  I don...
DNN Creative Subscribe
