Subject: Are You Usinf iFinity Moudle on DNN Creative?
mgordon
01 Jul 2009 12:28 PM
Hi Guys!
I've just downloaded your tutorials for using the iFinity module, but I'm wondering if you use it on DNNCreative, and if not, why?
Mark
Mark Gordon
Webmonkey
01 Jul 2009 2:51 PM
I currently do not use iFinity URL master module on DNN Creative quite simply because it scares me changing all the urls on the site when it is listed ok in the search engines. - I have made changes in the past for rankings where the change should have improved the rank but it's actually reduced the rank. - so, I'm not going to risk it with DNN creative, even though in theory everything should work out fine and even improve rankings due to the 301 redirects.
However, I have used this module on several new websites since creating the tutorial and any future websites I create will be using the module.
Forums > DotNetNuke® > Modules > Are You Usinf iFinity Moudle on DNN Creative?
Creating Portals before setting the host by cyborama
Hello Joe and Lee, I just took a look at your tutorial in reguards to parent and child portals an...
RE: How to close a website while you are working on it by mcmanta
Hey JoeThanks for the quick reply I will give that a try.best regardsTom
Good Morning - and Thanks Lee! I did send the upload error message to DataSprings as well, but ...
RE: Google Verification Code Question by BCRose
I found the solution. If anyone else wants to know this information you must go to your home page ...
Where do I place the Google verification code?I have been searching this site but cannot find any re...
Thanks Lee...I have been watching the videos. Lot's to learn here.
Start with:Setup Preparations for SkinningIntroduction to SkinningThen move on to some of the other ...
RE: How to close a website while you are working on it by jncraig
One way would be to assign two URLs -- a public URL and a private URL. Some hosting services provid...
RE: How to do links? by jncraig
There is a links module. If it has not been installed (and many modules are not installed by defaul...
RE: How to install DotNetNuke to Windows 7 - Issue 51 by jncraig
You need to purchase a subscription to DNNCreative Magazine.
RE: How to install DotNetNuke to Windows 7 - Issue 51 by jeihouni
hi,how can i download this video?is it free or i should pay for that?
RE: Enhancing the OWS Login Module and Building a Twitter Module - Issue 54 by bizcomit
How can I change the module/config to log-in using Enter Key ?
RE: DataSprings / Aweber by leesykes
Hello,When I created the tutorial for Aweber, the code they provided was placed within Form tags. An...
How to do links? by Guy..L
DNN Creative Subscribe
