Subject: Newsletter not sending verification email on subscriber email-id
kishor
29 Jun 2009 3:04 AM
Hi ,
I am using News letter in my project, whenever any one type there email id in newsletter text box, it does not send any verification code to subscriber email or no confirmation email.
I did setting in admin->site setting.
host->SMTP setting...
i have seen there is setting in newsletter setting ->Email setting can you tell how can i confugure this setting..
Or is there any other setting for this..
Thanks.
29 Jun 2009 1:45 PM
Take a look at How to set up email in DotNetNuke.
Forums > DotNetNuke® > Modules > Newsletter not sending verification email on subscriber email-id
RE: query regarding page options by leesykes
hello,If you do not wish your visitors to login, then I think the only other option will be to use c...
Localizing Skins and css dynamically based on language selected by sadabahar83
Hi, I want to dynamically assign a skin and CSS based on the language selected. Different pag...
Recomended DNN version? by lolorn
What version of DNN would be recommended for creating a new site? Has DNN 5.2 turned out to be as st...
query regarding page options by kaustav_kar
Hi,My site will have two Home pages, one for a new visitor and one for a returning visitor.   Is the...
RE: Plz Help. Page_Load_Exception by zaidkhan
URL of My website is www.pafkiet.edu.pk
Few new skins by Rozo
Skins for DNN and other CMS. www.stelg.com
RE: Plz Help. Page_Load_Exception by jncraig
Can you provide a URL?
RE: Custom Textbox Size by jncraig
For the second part, you can switch the editor to source mode and enter unstyled text. For the fi...
RE: Picture size limits by jncraig
The little red x's generally mean that the link to the image is broken.  My guess is that you have a...
RE: Uploading an MP3 file to my website by jncraig
web.config is in the root directory of your DotNetNuke installation.  ALWAYS (!!) make a backup copy...
RE: Customizing registration page by kana
Picture size limits by Doug_s
I'm lost - I've just changed host and a few thing that used to work don't, plus I can't display anyt...
RE: How to Limit Access to Administrator Modules in DotNetNuke 5 - issue 50 by samjst
Hi, Did you manage to solve the problem? I'm facing the same issue: users with access to add and...
Ealo Tab Localization help by sadabahar83
hi, I have installed Ealo Core Api and Ealo tab localization and ealo Menu provider. menu is wor...
Custom Textbox Size by PopeOMalley
Hello everyone,Do you know if there is a way to customize the size of a textbox control on the Manag...
RE: DotNetMushroom RAD by md-pv
That sounds interessting too. I'll check it. Thanks a lot.
thanks alot for replying Sir,Well.. my Under Construction Redirect issues are more general and they ...
RE: Uploading an MP3 file to my website by billkidwell
Joseph - I added the mp3 extenison to the list. It still diod not work. No error message but it did ...
Two things could go wrong.First, mp3 might not be an allowed file type.  You should have received an...
Joseph - Thanks, but I see my post was unclear. I tried to upload the MP3 and teh uplaod failed. No ...
