Subject: Events Module Question
mgordon
02 Oct 2008 2:35 PM
Hi All,
I am in the settings of the Events Module.  I want my editors additions, changes of events to be moderated.  There are three of us that will be moderating the Event Module.
My question is this:  In the "Moderation Settings" piece of the Module's settings, there is a field that says:
Moderator Email(s):
If you click on the question mark next to it, it says:  "Enter emails for notification when an event or enrollment require moderation."
Right!  This is what I want to do.  However, when I add more than one email address to this, it craps out on me.  I've tried the following formats:
name@pwcparks.org, name2@pwcparks.org, name3@pwcparks.org  (This craps out on me.  When I go to the next field it throws this error:
Valid Moderator Email Address required
I've also tried separating with semi-colons (;), to no avail.  I've tried wrapping ech addy in quotes.  Nopers.....no can do.
Anyone know the correct magical format for having more than one email addy in the Moderator Email(s) Field?
Mark
Mark Gordon
Webmonkey
03 Oct 2008 2:15 AM
Hi Mark,
That's what I would have tried as well, does anyone else have any suggestions? Otherwise I would ask the events module project team directly and see if they can give you the magic formula! - let us know if you find the solution as that will be useful to know,
Lee
omorgan
08 Oct 2008 10:38 AM
What about finding the location in the SQL Database and putting entering it directly into the DB table? Also I would try entering it in again with the semi(;) I've seen it in some cases, not necessarily with the events module, where once it triggers the validator it won't go until you refresh the page, or something like that.
Forums > DotNetNuke® > Modules > Events Module Question
RE: Module Advanced Setting by jncraig
The module contents is distinct and separate from the Module's container on a particular page. Wh...
RE: Community Edition Question by jncraig
The UDT Module has a new name: Form and List. Look for that. If it is not installed, it shoul...
DataSpring Opt In Module - Scheduler Question by wynnjon
Hey-I was wondering if anything special had to be done to keep the site alive so that the scheduler ...
RE: the now content not showing and still showing the old one by jncraig
You probably can't. Your browser is caching the old flash file, and CRTL-F5 forces a reload. If yo...
RE: Nav Menu v2 for DotNetNuke v5 - Issue 52 by jncraig
Here is a nice little blog entry on the subject.(Basically, though, this gives you a nice and clean ...
RE: Flash in the HTML Module by robmacker
OK, so i commented out my AC_RunActiveContent.js file and my HTML module runs the same -- telling me...
RE: Flash in the HTML Module by mcmanta
I had the same problem before. I noticed I had some HTML tags from some error text I copied. I was a...
Thanks for the reply Joe, The way my hosting company does things they don't have per say host hea...
Wow, why does the forum format my question to make it basically unreadable?? I certainly did not typ...
Hello members! I have a simple flash application that was written for an HTML page and i'm trying...
Send email with Dynamic Forms Results by jesp17
Hello, Is there a way to automatically generate a report with all form results and then send this r...
Community Edition Question by idesofmarch
I'm learning a lot just browsing around here. Wish I could delete my question below. Oh well. Wher...
RE: DNN Site crashed after module install by mcmanta
I found a work around. Looks like the module replaces the Telerik.Web.UI located in the bin folder o...
RE: iHostASP by chandirika
Hi,I am reselling account with this http://www.goresellers.com/ site ,for my web site's web hosting...
the now content not showing and still showing the old one by wael_e
after i uploading the new contenct in my website and i uploading static html page have introdaction ...
RE: Regular Expression by jumatthey
Hi, Thank you very much Mark. It is indeed a name I am checking. Thank you for your help, very mu...
I think this website is properly structured in that I can drop the requirement to exclude certain pa...
RE: Nav Menu v2 for DotNetNuke v5 - Issue 52 by kparker
What are the advantages of setting the RenderMode to UnorderedList for the Nav Menu? How can this b...
RE: DNN Site crashed after module install by jncraig
Most likely, the module that you installed uses a Telerik library that is different from the one tha...
Hello All,I'm using DNN 5.2.3 after install everything was working fine. I installed the 365 Simple ...
