Subject: Can't add custom module - help please
gzhu
28 Sep 2008 7:41 AM
I am trying to create a module using Linq in VS.net. All goes well and my control builds in VS. I am able to create a module definition in DNN and link it through to my control. Unfortunately when I try to add the control to a web page it bombs out with the below error. It appears to be a compilation error but I dont know what has gone wrong. Can some kind soul help a newbie out.
Cheers
Geoff Scott
Error: FacPatients is currently unavailable.
DotNetNuke.Services.Exceptions.ModuleLoadException: External component has thrown an exception. ---> System.Web.HttpCompileException: External component has thrown an exception. at System.Web.Compilation.AssemblyBuilder.Compile() at System.Web.Compilation.BuildProvidersCompiler.PerformBuild() at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at DotNetNuke.UI.Skins.Skin.InjectModule(Control objPane, ModuleInfo objModule, PortalSettings PortalSettings) --- End of inner exception stack trace ---
28 Sep 2008 9:05 AM
There's not enough information there to help. If you look at the event log for your site, there may be more.
Also, you get this the first time you try to place the module on a page?
Forums > DotNetNuke® > Modules > Can't add custom module - help please
RE: How to Create Module : by jncraig
I'd recommend the book on DotNetNuke module development by Mitchel Sellers, and also adefwebserver.c...
RE: Change Login Page by jncraig
If you want to add modules to the login page, first create on and add the login module. Then add ot...
RE: Background colour by jncraig
RE: [Server Error]This error can be caused by a virtual directory not being configured as an application in IIS. by arm
Posted By mnaoj on 04 Dec 2008 11:46 AMError 1 It is an error to use a section registered as allowDe...
How to Create Module : by hassangas2003
this first my question in aforum,i'm abeginer in DNN,I have web user control already used to old pro...
Background colour by petecarrick
Hi,Sorry if this is a real dumb question, I've been experimenting with the Vortex skin and I have ch...
RE: Horizontal menu vertical borders by petecarrick
That worked perfectly, thanks very much Lee.Pete
Change Login Page by edeakin
Hey guys it’s me again. Great work on session 46 keep up the great work! I want to be able to add m...
RE: Module Wrapper & Tab Aggregator?? by gbrown
Found the Ajax Module Wrapper from Gumbosoft. Bought it and tried it - it works inside of Tab Aggreg...
Has anybody tried to place a Module Wrapper module from ZLDNN inside a Tab Aggregator module from DN...
RE: SWF Tutorial Conversion by raymueller
Thanks and I will continue to research. Each of the applications pick up the introduction (~ 20-25 s...
RE: Please do review by leesykes
There are a couple of things that you could look at:Initial page load time of the sites was slow, t...
RE: Module Development - Settings Page by leesykes
thanks for letting us know the solution and if there's anything else we can help out with please let...
RE: SWF Tutorial Conversion by leesykes
not sure, its not something I have tried, the swf should convert, perhaps its worth googling around ...
RE: not been able to download videos by leesykes
RE: Styling the main menu by leesykes
When you add code to your skin.css file, make sure you press CTRL+F5 to reload the page and reload t...
RE: Horizontal menu vertical borders by leesykes
To find the id of the menu item, use the web developers toolbar for Firefox, go to information menu...
RE: Module Development - Settings Page by HMDevelopment
Hello Lee. No thanks -- I have still earned value from this site. I did quite a few 'video' tutor...
RE: Can I modify the Default Events module only for a Portal? by jncraig
If you create a skin for your site, it will apply only to your site.  Also, portal.css applies only ...
RE: How to prevent auser from multiple login. by jncraig
