Subject: Newsletter Module
akarasi
04 Jan 2008 4:28 AM
     I need newsletter module for my portal.I searched for the Download option for Newsletter module.I coudn't  find on DnnCreative.com.But I found in orizonti.com.I downloaded that  and i used.But unfortunately, it hasn't function for sending mail or any option.It asks for only Name and emailid and has Subscribe Button.
If i click that nothing is happening.
Can anybody help me that where i can see the this module (perfect working)
Regards,
Akarasi
Forums > DotNetNuke® > Modules > Newsletter Module
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
