Subject: Dnncovered Newsticker Module
dnncovered1
06 Jul 2007 10:48 AM
Dnncovered.com is proud to release their famous Newsticker module, Newsticker 3.1.0, compatible with both DNN 3.xx and DNN 4.xx. NewsTicker 3.1.0 is equipped with new features like Multiple RSS feed, ability to customize the styles of the news and links.
Click here to download the FREE Trial version.
http://www.dnncovered.com/Store/tabid/169/CategoryID/6/List/0/SortField/0/Level/1/ProductID/97/Default.aspx
Click here to find other Newsticker versions:
http://www.dnncovered.com/Store/tabid/169/List/0/CategoryID/6/Level/1/SortField/0/Default.aspx
DNNCovered.com
Web Marketing Consultant
DNN Covered is a one stop solution for buying and selling skins, modules and portals based on DNN (Dotnetnuke) framework.
sales@dnncovered.com | Memberships | Free DNN Stuffs | Contact Us
Forums > DotNetNuke® > Modules > Dnncovered Newsticker Module
RE: PowerDNN by jazzylily
RE: PowerDNN by DavidWSnow
RE: PowerDNN by mgordon
Great!
RE: PowerDNN by MobileNow
