Subject: Store Menu: Object reference not set to an instance of an object.
f3nd3r
20 Apr 2007 9:39 AM
Hey guys,
There is a category in the Store Menu module which i would like to delete, however whenever i attempt to delete it i am presented with the error: "Object reference not set to an instance of an object." and consequently the category remains undeleted.
Any help with this would be much appreciated.
Forums > DotNetNuke® > Modules > Store Menu: Object reference not set to an instance of an object.
RE: Server Application Unavailable from localhost by picoallen
OK, I've got things working better now. Not sure why though as I lost track while following all the ...
e-Survey? by mgordon
I need a module that will do the following:When a person comes to a specific page (recreation guide ...
