Subject: XML module-timeout when page is down
tiktakit
14 Dec 2006 5:11 PM
I'm using the basic dnn xml/xsl module. My problem is that sometime the XML page I feed is down, and I want to prevent the module of getting a timeout. Does anybody knows a way to do it ? I thought about these directions:
* thorugh the XSL I'm using to style the XML
* Creating a pre-XML page that will call my target XML, and will first check if it's not down - is that an option anyway?
Hadar
Forums > DotNetNuke® > Modules > XML module-timeout when page is down
RE: Server Application Unavailable from localhost by picoallen
OK, I've got things working better now. Not sure why though as I lost track while following all the ...
e-Survey? by mgordon
I need a module that will do the following:When a person comes to a specific page (recreation guide ...
