Subject: error in using javascript in controls
parag
22 Dec 2005 11:21 AM
<asp:hyperlink runat="server" Text=''<%# DataBinder.Eval(Container, "DataItem.Cname")%> NavigateUrl="DoSubmitItemSelected(<% # DataBinder.Eval(Container, "DataItem.Cno" )%>)ID="Hyperlink1">
DoSubmitItemSelected: this is my javascript fuction and i m passing  (<% # DataBinder.Eval(Container, "DataItem.Cno" )%>) this value to function but i could not pass it because of error...
i m useing this in my control but it gives me error that could not open this in design view. Quates value differntly inside<% "Value" %> block
please help me in this.....
parag
Forums > DotNetNuke® > Modules > error in using javascript in controls
RE: Server Application Unavailable from localhost by picoallen
OK, I've got things working better now. Not sure why though as I lost track while following all the ...
e-Survey? by mgordon
I need a module that will do the following:When a person comes to a specific page (recreation guide ...
