Subject: House of Nuke Menu
GiSu
08 Aug 2008 4:05 PM
I have an issue with using House of Nuke menu on a site I have set up a horizontal menu as below:
P1    P2    P3
C1    C1    C1
C2    C2    C2
C3    C3    C3
P=Root menu items
C=Children
I want to use the P's as headers for the C's.
I created dummy P pages with Public view privileges and checked "Disabled" to be the headers. Then, I added the children to them.
It works fine as long as I'm logged in with administrator privileges. As soon as I log out, the menu disappears. My guess is that they don't show up because they are disabled.
Do you have any suggestions on how to make the menu behave as I want it to.
GiSu
09 Aug 2008 12:33 AM
Issue is resolved. I did not have view privileges set to Public. One little click is all it took.
11 Aug 2008 5:45 AM
great, glad you sorted it
Forums > DotNetNuke® > Modules > House of Nuke Menu
RE: Pop up window by jncraig
Pop up window by yerann
