| Firefox Does Not Display WMV File In Media Module by johnmk777 |
| Hi All,I can't believe I am having such a hard time finding and answer to this question. I have see... |
| advice wanted convert site to DNN while keeping existing asp functionality by max2o |
| I am running into the issue that a client wants to redesign their site and they want content managem... |
| RE: Site is not opening by leesykes |
| from the message it is referencing php - is it a dnn site? - is asp.net applied for the site? |
| RE: SolPart Menu Font Color Control by leesykes |
| Hello,I'm not aware of any documentation at the moment. But here is a list of Nav Menu PropertiesTo ... |
| Site is not opening by kaustav_kar |
| Hi,Whenever I'm writing the url (http://tajfood.com.sa) it's showing the following error;
Index of ... |
| RE: SolPart Menu Font Color Control by cdees |
| Lee, Is there documentation, or perhaps a tutotial on activating and using Nav menu? Where would I... |
| RE: EasyCGI help? by Dr Joe |
| I found some interesting posts on some other sites that explain some of the challenges I've been exp... |
| RE: Menu's, menu's, and more menu's! by roadshow41 |
| Thanks! I'm still a bit curious about some of the other options, but I think that gives me enough c... |
| RE: Menu's, menu's, and more menu's! by leesykes |
| Hello,Yes that should be possible with snapsis, I have used snapsis CSS with flyout menus on a horiz... |
| I typically end up using a hybrid of a vertical menu and a horizontal menu due to the sheer number o... |
| DotNetNuke SEO (Search Engine Optimization) by leesykes |
| Hello,I regularly get asked for tips on SEO with DotNetNuke, there are several resources available o... |
| Hello,If you are looking for a menu for SEO reasons, any CSS based unordered list menu will be SEO f... |
| Well, I've been trying to steam ahead with the DNN sites I inherited a few months ago. I've found l... |
| RE: EasyCGI help? by derpir |
| Hi Lee
I told them that solution two days ago and still no answer, but thanks for suggesting that s... |
| RE: quick question by derpir |
| Hithanks! yes I understand. I will deal with my skins more tomorrow, maybe some questions will arriv... |
| RE: Restart Application by leesykes |
| It will restart your DotNetNuke installation and reload the application.Clearing cache will clear th... |
| RE: How can i edit any module from front end by leesykes |
| hello,I have just tested this and can see exactly the same as you, I suspect the core team have set ... |
| RE: EasyCGI help? by leesykes |
| You may want to ask them to reset the correct permissions on your DotNetNuke installation files, som... |
| RE: quick question by leesykes |
| Hello,It will be possible to a degree, but it depends on how both of the skins have been built. You ... |
| I'll let you know how it works out. I think I opened up about 6 tickets with them so far. ... |
