Subject: Tell a Distribution List Module
greenglow
04 Jul 2008 10:28 AM
We're looking for a DNN Tell a Friend module that allows people to forward the page to a distribution or group list along with one at a time forwards.   Does anyone have anything like that? It would need to interface with the users e-mail clinet so that he or she could send to a group list without having to copy and paste.
05 Jul 2008 9:34 AM
There are several "Tell a Friend" modules. At least one is free -- just Google "DotNetNuke Tell a Friend" to find them. I don't believe that I've seen one that will take addresses automatically from your email address book.
Forums > DotNetNuke® > Modules > Tell a Distribution List Module
RE: Pop up window by jncraig
Pop up window by yerann
