Subject: Default Events Module XHTML
emedia
21 May 2008 6:46 PM
Hey guys,
I'm new to DNN and have been trying to make a specific install of DNN XHTML compliant.  Generally this has been fairly straight foward, especially using the XHTML tutorial here at DNN creative.  However the default Events Module of DNN (free one) is causing me a problem with 3 specific errors that I can't seem to isolate - I know how to fix them - but can not find the place to edit these in the code.
The first two just need type="text/javascript" in them while the last one possibly just needs to be moved up the page (althrough not totally sure on this).  My problem is that for the Events Module I can't find the place in the DNN source code to make thsee changes, it may be in a DLL I'm not sure.  If anybody can tell me were/how to make these chanegs or could offer any help that would be much appriciated.
Chris
  1. Error Line 18, Column 95: required attribute "type" not specified.
    …pt>[script removed]
    <P class=helpwanted><A title="Suggest improvements on this error message through our feedback channels" href="http://validator.w3.org/feedback.html?uri=http%3A%2F%2Fqldc.dnnvalid.emedia.net.nz%2FQLDCEvents%2Ftabid%2F108%2FDefault.aspx;errmsg_id=127#errormsg"></A> </P>
    <DIV class="ve mid-127">
    <P>The attribute given above is required for an element that you've used, but you have omitted it. For instance, in most HTML and XHTML document types the "type" attribute is required on the "script" element and the "alt" attribute is required for the "img" element. </P>
    <P>Typical values for <CODE>type
    are
    type="text/css"
    for
    <style>
    and
    for
    [script removed]
    <LI class=msg_err><SPAN class=err_type><IMG title=Error alt=Error src="http://validator.w3.org/images/info_icons/error.png"></SPAN> <EM>Line 18, Column 152</EM>: <SPAN class=msg>required attribute "type" not specified</SPAN>.<PRE><CODE class=input>…c="/DesktopModules/Events/tooltip.js"<STRONG title="Position where error was detected.">></STRONG>[script removed]
    Typical values for
    type
    are
    type="text/css"
    for
    <style>
    and
    for
    [script removed]
    <LI class=msg_err><SPAN class=err_type><IMG title=Error alt=Error src="http://validator.w3.org/images/info_icons/error.png"></SPAN> <EM>Line 40, Column 97</EM>: <SPAN class=msg>document type does not allow element "link" here</SPAN>.<PRE><CODE class=input>…s" type="text/css" rel="stylesheet" /<STRONG title="Position where error was detected.">></STRONG>
    The element named above was found in a context where it is not allowed. This could mean that you have incorrectly nested elements -- such as a "style" element in the "body" section instead of inside "head" -- or two elements that overlap (which is not allowed).
    One common cause for this error is the use of XHTML syntax in HTML documents. Due to HTML's rules of implicitly closed elements, this error can create cascading effects. For instance, using XHTML's "self-closing" tags for "meta" and "link" in the "head" section of a HTML document may cause the parser to infer the end of the "head" section and the beginning of the "body" section (where "link" and "meta" are not allowed; hence the reported error).
emedia
22 May 2008 3:48 AM
I can't seem to locate the Visual Studio Solution file for the Events Module, I know most modules normally have a Visual Studio Solution file in the zip file but the Events one doesn't seem to contain this.  If somebody could point me to where the VS Solution File for the Events Module is that would be great.  Any help much appriciated.  I am refering to the latest version that is 03.03.08
23 May 2008 8:16 AM
Checkout:
RC3 of events module
events and visual studio 2008
where is events source?
Forums > DotNetNuke® > Modules > Default Events Module XHTML
RE: Pop up window by jncraig
Pop up window by yerann
