Subject: Editing Blog Module to say News instead of Blog
omorgan
21 May 2008 8:27 AM
I'm trying to find where I can edit the blog module from saying Blog to make it say News. My boss doesn't like the word blog and I need to change it every where it shows up. I have changed it every where in the language packs, but when I click on a child-blog down at the bottom it still says "Blogs > Clidblogname" and I need to have that changed but can't find it.
Owen
22 May 2008 11:21 PM
I believe that I saw an answer for you in the DotNetNuke forums. Did you get it?
omorgan
23 May 2008 6:45 AM
Yep just got it, thanks for checking on it Joe.
eonelson
10 Jun 2008 10:08 AM
This looks like it could answer part of my question. . . where is the answer you refer to?
Thanks.
Eileen
11 Jun 2008 7:31 PM
Look in the "Blog" forum at DotNetNuke.com.
Forums > DotNetNuke® > Modules > Editing Blog Module to say News instead of Blog
RE: Pop up window by jncraig
Pop up window by yerann
