Subject: Zip files getting corrupted when downloaded
omorgan
19 May 2008 2:35 PM
Howdy,
I'm having a problem with my websites ability to download zip files. I have tested this as well as a user and when I download a zip file through DotNetNuke (UserDefinedTable) it corrupts the zip file. I've downloaded it directly by browsing to the URL without any issues. I'm currently testing the Documents Module but was wondering if anyone else has this problem? The files are rather large, between 50 and 150 MBs. Any ideas?
Owen
19 May 2008 11:13 PM
You need to go into web.config and fix the setting for the maximum file size. It's default value is around 8 megs, so if you have larger files, you'll have to increase it. You may also need to increase some timeouts to make sure that the files get delivered without page timout errors.
omorgan
20 May 2008 8:09 AM
Thanks Joe,
I wondered if it was something like that but wasn't sure where to look. I'll go ahead and tweak it and give it a try. Funny enough, instead of using the "download" part of the UDT, if you use the URL and select file that way it doesn't give you any problems. Go figure.
Owen. - http://www.fdwsnetworks.com
20 May 2008 9:17 AM
Hmmm ... let us know what you find.
fyz
05 Jun 2008 7:53 AM
If you still can't solve the problem, you can try some professional services to repair the corrupt zip file. I think you can try an utility called Advanced Zip Repair to repair your Zip file. It works rather well for my corrupt Zip files.  If you don't need such tool, please just ignore this.
Alan
Forums > DotNetNuke® > Modules > Zip files getting corrupted when downloaded
Need UK Hosting by Liz
Web.config Error by derpir
Yahoo Answers by cdtguru
RE: Videos by clippy
skinning trouble by derpir
RE: Template Issue by jncraig
