Subject: Paging in FAQs module
ranjeet
16 May 2008 12:04 AM
I added a FAQs module in DNN project and want to implement paging on this module how it will done.I am new for DNN.
17 May 2008 8:12 PM
I don't believe that paging is part of the FAQ module.
Forums > DotNetNuke® > Modules > Paging in FAQs module
RE: Pop up window by jncraig
Pop up window by yerann
