Subject: Paging in FAQs module
ranjeet
16 May 2008 12:02 AM
I added a FAQs module of DNN and want to implement paging on this
this module how it will done.I am new for DNN.
19 May 2008 7:57 AM
Currently there is not a setting to enable paging in the FAQ module.
Forums > DotNetNuke® > Modules > Paging in FAQs module
RE: Pop up window by jncraig
Pop up window by yerann
