Subject: Module development - VS2005 VS2008 C# module template
andyb1979
14 May 2008 4:31 PM
Hi all,
I found a module template for developing modules in C# on VS2005 at this address:
http://www.bitethebullet.co.uk/DNN4CSharpTemplate/tabid/79/language/en-US/Default.aspx
The author of the template has just released a VS2008 version, which Im currently using to try to develop my first module! It seems pretty simple to get up and running. But you'll need to know a little about SQL server and ASP.NET development to create a working module.
I'll let you know how I get on! ...
Andrew
Rock Rhyme & Reason Fest | The Big Match
17 May 2008 8:12 PM
Great.
Forums > DotNetNuke® > Modules > Module development - VS2005 VS2008 C# module template
RE: Pop up window by jncraig
Pop up window by yerann
