Subject: Enhance Registration Module
kazirameez
14 May 2008 7:11 AM
Hi everyone,
I'm looking some good read (and suggestions) on how can we modify the registration page of DNN? I have been through to the DNN Registration form customization but I've to do something a bit ahead. I can manage partially customizing the Registration fields but with that there should be a shipping/billing forms which I like to plug as a section and that shipping data should be saved into someother database.
The thing is this all should all in one page which should be registration page and is there any way to overwrite the redirection after registration completed?
Please, suggest whatever you think should be best on this. Thanks!
Nuke Master I
Nuke Master I
14 May 2008 8:46 AM
Take a look at DataSprings' Dynamic Registration and Dynamic Login modules.
Forums > DotNetNuke® > Modules > Enhance Registration Module
Missing subscriber access by stefanheskjaer
I subscribed on 07-01-2008 and received my confirmation from PayPal. Still unable to access the vid...
Define Style by Vereen84
A style sheet is a free-flowing document that can either be referenced by, or included into a HTML d...
Tell a Distribution List Module by greenglow
We're looking for a DNN Tell a Friend module that allows people to forward the page to a distributio...
XML settings for Feedback Module by saintX
Hello,I don't want the help (blue question marks) to be dispalayed besides the fields of the feed ba...
shadowmu by gunitshadow
Server Info:XP: 100xDB: FreshDrop: 85%Version: S3 Episode1 PremiumShops: FULLSpots: FULLUptime: 24/7...
RE: Calendar Strobe? by leesykes
Hello,Welcome to th forum, when I hover over a link in IE7, IE6 they display just the same as FF2 - ...
RE: Custom HTML Skin - link module center overridden with left align by leesykes
Not sure what is happening here, I tested again in FF2 in view mode and the links are centered.I hav...
RE: HouseMenu doesnt work by leesykes
Hello,Check out this forum post for some quick tips with HouseMenu
RE: Issue 34 New Skins and House Menu by leesykes
RE: Open menu links in new window? by leesykes
Hello,If you attach the code in a zip file to your forum post we can have a look, thanks,
RE: File Manager with Limited Access by leesykes
Hello,I have just tested this and have the same problem. Perhaps it would be worth looking for docum...
RE: how to develop skins in dotnetnuke by leesykes
Hello,If you go to the main tutorials page and scroll to the bottom you will see a big list of skinn...
RE: deploy developed wedsite by leesykes
Hello,You may find these tutorials useful,How to transfer a localhost DotNetNuke installation to a l...
RE: Please help me in choosing web hosting by leesykes
I would recommend you view the comments on hosting providers in the hosting section of this forumI w...
RE: Is posible creating multiple website (portal) in a single DNN installation? by leesykes
You can do that approach, if it is a localhost installation, you may find it quicker to create child...
how to develop skins in dotnetnuke by rao_babu24
how to develope skins for dotnetnuke  thanks advance
deploy developed wedsite by rao_babu24
how to  deploy developed wedsite thanks advane
Please help me in choosing web hosting by 0xyGen
Hi everyone,I am sorry for possible offtopic, but I need your help in find new web hosting provider ...
RE: Is posible creating multiple website (portal) in a single DNN installation? by aravinthkula
Thanks for your reply. Actually we followed a approach like created different portal like portal1 a...
File Manager with Limited Access by tds_softwaredev
Hi Everyone, I was hoping someone might have a solution for a little problem I have run into. I w...
