Subject: Enhance Registration Module
kazirameez
14 May 2008 7:11 AM
Hi everyone,
I'm looking some good read (and suggestions) on how can we modify the registration page of DNN? I have been through to the DNN Registration form customization but I've to do something a bit ahead. I can manage partially customizing the Registration fields but with that there should be a shipping/billing forms which I like to plug as a section and that shipping data should be saved into someother database.
The thing is this all should all in one page which should be registration page and is there any way to overwrite the redirection after registration completed?
Please, suggest whatever you think should be best on this. Thanks!
14 May 2008 8:46 AM
Take a look at DataSprings' Dynamic Registration and Dynamic Login modules.
Forums > DotNetNuke® > Modules > Enhance Registration Module
RE: Pop up window by jncraig
Pop up window by yerann
