Subject: right alignment of paragraph in text or html module...
meenu
07 May 2008 3:16 AM
dear all i am using dnn0408...
i have one text/html module....
in this module i wrote some text...that test alignment is left...
can u check the paragraph below...in that paragraph...left side alignment is ok...but right side alignment is ugly...how i can do this paragraph alignment perfectly on both left and right sides...
use GPS / GSM tracking and communication system. Hud Hud enables you to locate, track and communication with fleets of any size through Sultanate of Oman and beyond.Our easy to use, cost-effective solution combines Global Positioning System technology, wireless communications and the Internet to enable companies to efficiently manage the movement of vehicles with location, reporting, dispatching, messaging and management services. Our service allows customers to track the movement of their vehicles, employees, goods and services, providing detailed information for managing mobile resources. As a result, we believe our service provides significant value to our customers by reducing their costs of doing business and increasing the safety of driver
Nuke Master I
Nuke Master I
07 May 2008 8:53 AM
The editor toolbar has an icon for "justify" right next to the left, right, and center icons.
Alternately, in html source mode you can wrap the text with a tag like
< div align="justify" >
text
< /div >
You can also use span or other tags that use align as a parameter.
meenu
11 May 2008 11:53 PM
thank u so much ......
i done this based on ur suggestion...
regards
Forums > DotNetNuke® > Modules > right alignment of paragraph in text or html module...
Missing subscriber access by stefanheskjaer
I subscribed on 07-01-2008 and received my confirmation from PayPal. Still unable to access the vid...
Define Style by Vereen84
A style sheet is a free-flowing document that can either be referenced by, or included into a HTML d...
Tell a Distribution List Module by greenglow
We're looking for a DNN Tell a Friend module that allows people to forward the page to a distributio...
XML settings for Feedback Module by saintX
Hello,I don't want the help (blue question marks) to be dispalayed besides the fields of the feed ba...
shadowmu by gunitshadow
Server Info:XP: 100xDB: FreshDrop: 85%Version: S3 Episode1 PremiumShops: FULLSpots: FULLUptime: 24/7...
RE: Calendar Strobe? by leesykes
Hello,Welcome to th forum, when I hover over a link in IE7, IE6 they display just the same as FF2 - ...
RE: Custom HTML Skin - link module center overridden with left align by leesykes
Not sure what is happening here, I tested again in FF2 in view mode and the links are centered.I hav...
RE: HouseMenu doesnt work by leesykes
Hello,Check out this forum post for some quick tips with HouseMenu
RE: Issue 34 New Skins and House Menu by leesykes
RE: Open menu links in new window? by leesykes
Hello,If you attach the code in a zip file to your forum post we can have a look, thanks,
RE: File Manager with Limited Access by leesykes
Hello,I have just tested this and have the same problem. Perhaps it would be worth looking for docum...
RE: how to develop skins in dotnetnuke by leesykes
Hello,If you go to the main tutorials page and scroll to the bottom you will see a big list of skinn...
RE: deploy developed wedsite by leesykes
Hello,You may find these tutorials useful,How to transfer a localhost DotNetNuke installation to a l...
RE: Please help me in choosing web hosting by leesykes
I would recommend you view the comments on hosting providers in the hosting section of this forumI w...
RE: Is posible creating multiple website (portal) in a single DNN installation? by leesykes
You can do that approach, if it is a localhost installation, you may find it quicker to create child...
how to develop skins in dotnetnuke by rao_babu24
how to develope skins for dotnetnuke  thanks advance
deploy developed wedsite by rao_babu24
how to  deploy developed wedsite thanks advane
Please help me in choosing web hosting by 0xyGen
Hi everyone,I am sorry for possible offtopic, but I need your help in find new web hosting provider ...
RE: Is posible creating multiple website (portal) in a single DNN installation? by aravinthkula
Thanks for your reply. Actually we followed a approach like created different portal like portal1 a...
File Manager with Limited Access by tds_softwaredev
Hi Everyone, I was hoping someone might have a solution for a little problem I have run into. I w...
