Subject: right alignment of paragraph in text or html module...
meenu
07 May 2008 3:16 AM
dear all i am using dnn0408...
i have one text/html module....
in this module i wrote some text...that test alignment is left...
can u check the paragraph below...in that paragraph...left side alignment is ok...but right side alignment is ugly...how i can do this paragraph alignment perfectly on both left and right sides...
use GPS / GSM tracking and communication system. Hud Hud enables you to locate, track and communication with fleets of any size through Sultanate of Oman and beyond.Our easy to use, cost-effective solution combines Global Positioning System technology, wireless communications and the Internet to enable companies to efficiently manage the movement of vehicles with location, reporting, dispatching, messaging and management services. Our service allows customers to track the movement of their vehicles, employees, goods and services, providing detailed information for managing mobile resources. As a result, we believe our service provides significant value to our customers by reducing their costs of doing business and increasing the safety of driver
07 May 2008 8:53 AM
The editor toolbar has an icon for "justify" right next to the left, right, and center icons.
Alternately, in html source mode you can wrap the text with a tag like
< div align="justify" >
text
< /div >
You can also use span or other tags that use align as a parameter.
meenu
11 May 2008 11:53 PM
thank u so much ......
i done this based on ur suggestion...
regards
Forums > DotNetNuke® > Modules > right alignment of paragraph in text or html module...
RE: Pop up window by jncraig
Pop up window by yerann
