Subject: Host Tab Missing?
nate
07 Jan 2008 2:12 PM
Well I recently purchased a store module to install on my DNN 4.4.1 portal. Today when I went to install it I logged in as administrator only to find the Host tab has completely dissapeered. I am at a loss as to how to get it back, and was hoping someone here may have some insight.
Thanks in advance,
-Nate
07 Jan 2008 2:16 PM
You need to stop and then restart IIS, or reboot your server. Something has gone awry ...
(This happened over the weekend to one of my websites, too.)
nate
07 Jan 2008 2:40 PM
OK I'll give that a shot now...
nate
07 Jan 2008 3:13 PM
nope still no host tab
I know it was there last time I logged in as admin to install some skins about 6 months ago...
07 Jan 2008 3:27 PM
This may seem like a daft question but when you say you logged in as administrator - did you log in as host? - Only the host user can see the host menu, the admin user can only see the admin menu.
nate
07 Jan 2008 3:36 PM
Yep that was the problem. I guess I misunderstood the function of the admin acct as I thought admin can see the host menu as well. This issue is fixed...
07 Jan 2008 3:39 PM
great, glad to help,
07 Jan 2008 4:14 PM
Oh, that's it!
ananda
09 Jan 2008 3:43 PM
My admin tab is missing when I log in as admin. My host tab is missing when I log in as host. I installed my dnn site in a virtual directory under the website, and I don't know if that matters. Does anyone know what I can do to fix the problem? Does anyone know what the problem is?
10 Jan 2008 3:27 AM
you should not have problems from installing in a virtual directory, do you see the admin menu when logged in as host? - is this a fresh installation on a localhost installation?  It could be worth attempting a re-install. - has this installation previously been working? it's odd that the menu items have just disappeared, if you can provide any further information we may be able to help.
ananda
14 Jan 2008 12:05 PM
Actually, the results were the same after my fourth reinstall.  However, I have isolated the problem after installing the web site on a different server, with no problems.
I have not narrowed down the issue yet, but it is either in the IIS headers that control caching and content expiration, or it is a result of inherited web.config settings from the parent folder.  The IIS root has content expiration set to immediate, and all HTTP headers removed.  The parent folder's web.config uses a different method of forms authentication than the DNN site.  I suspect the later because the admin and host menu tabs only appear after a successful login, so the login must not have been successful.
ananda
14 Jan 2008 7:23 PM
I isolated the problem to some settings inheritance from the root web application's web.config.
I had to override two web.config settings sections in the dnn root directory to get the DNN login working correctly. I overrode the parent folder's < authorization > section:
< authorization >
  < deny users="?"/ >
< /authorization >
I also had to override a duplicate httpModule ScriptModule reference from the parent folder's web.config:
< add name="ScriptModule" type="System.Web.Handlers.ScriptModule, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" / >
The added entries in my working DNN site's web.config look like this:
< system.web >
  < httpmodules >
    < !-- Be careful not to use the < clear / > tag here! That breaks the login process. -->
    < remove name="ScriptModule"/ >
  < /httpmodules >
  < authorization >
    < allow users="*,?"/ >
  < /authorization >
< /system.web >
ananda
14 Jan 2008 7:34 PM
Well, the XML didn't display correctly in the above post, so I posted the same response here:
http://www.dotnetnuke.com/Community/Forums/tabid/795/forumid/107/threadid/79793/scope/posts/threadpage/3/Default.aspx
15 Jan 2008 2:08 AM
Thanks for the info, if you wish to post code add a space after < and before > - you can do this quickly using notepad or a html editor, just press ctrl+h to find and replace and find < and replace with <(space), find > replace with (space)>
Quentin
23 Feb 2009 9:08 AM
Hey guys, I hope someone is still able to give me some advice on this topic.  By the way, when answering assume you are talking to a complete idiot please.
I had my DNN installed by someone else, who at the time was managing it for me as well (adding modules, etc.).  He has since moved on and I am left to try and understand how all this works.  I was trying to upload a new module and in reading it talks about logging in as 'host'.  This is where I have a problem.
When I get to log in it does not give me a choice of Host or Admin.  At the top of my webpage is a key with the word login.  when I hit that it takes me a page with a username and password.  After entering that I get access to my page where I can alter text, add pictures and so on.  It also give me a pull down menu called Admin.  This allows me to do all the administrative stuff.
But there is nothing marked host.  Help please.
I can log on to Plesk control panel and manage my files from there, but that doesn't seem to help.
What can I do as I would really like to add some new features to my site.
Any answers would be greatly appreciated.
23 Feb 2009 9:16 AM
If this was set up in a standard way, you will have a username "host" and a username "admin."  If you login as host, you will see the host menu and the admin menu.  If you login as admin, you'll see only the admin menu.
It would seem that you logged in as admin.
The Plesk control panel won't help you here ...
Quentin
23 Feb 2009 9:33 AM
Hmm, there is obviously a problem with my DNN install then as I only get presented with one choice of log in, which as I said, when it opens my page give me the admin activities.  I have just tried to reset the skin by going to 'restore default', but that has no effect.  Is there anyway to get teh host features back?
Would upgrading to a newer version of DNN overcome this?  And if so, then the next really dumb question is, how do I do that?
Regards
Quentin
23 Feb 2009 9:42 AM
When you say that you are presented with only one choice, can you explain more?
Normally, you would see a login box where you can enter a username and password.  I assume that you are seeing something different.
Can I see the site?  Click my name to send an email if you don't want to put it in public.
Quentin
23 Feb 2009 6:01 PM
Thanks Joe, replied to your email.
amit
29 Oct 2009 4:17 AM
Posted By Quentin on 23 Feb 2009 6:01 PM
I am also facing the same problem whenever i get logged in as a host user. The host and admin tab got disapper also i am unable to Edit the content.
Whenever i click on user links it giving me this error.
DotNetNuke Error: - Version 04.05.03
An error has occurred.
DotNetNuke.Services.Exceptions.PageLoadException: '~/images/icon_users_32px.gif [script removed] ' is not a valid virtual path. ---> System.Web.HttpException: '~/images/icon_users_32px.gif [script removed] ' is not a valid virtual path. at System.Web.Util.UrlPath.CheckValidVirtualPath(String path) at System.Web.Util.UrlPath.Combine(String appPath, String basepath, String relative) at System.Web.UI.Control.ResolveClientUrl(String relativeUrl) at System.Web.UI.WebControls.Image.AddAttributesToRender(HtmlTextWriter writer) at System.Web.UI.WebControls.WebControl.RenderBeginTag(HtmlTextWriter writer) at System.Web.UI.WebControls.WebControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at ASP.portals__default_containers_dnn_blue_text_header___white_background_ascx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) in D:\www4\elephantdesign.com\Portals\_default\Containers\DNN-Blue\Text Header - White Background.ascx:line 40 at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at ASP.portals__default_skins_elephant_skin1_index_ascx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) in D:\www4\elephantdesign.com\Portals\_default\Skins\Elephant_skin1\index.ascx:line 90 at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Page.Render(HtmlTextWriter writer) at DotNetNuke.Framework.PageBase.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) --- End of inner exception stack trace ---
can you please provide me the solution.
Regards,
Amit.
29 Oct 2009 5:59 AM
Did this just start happening, or has the site never worked.
Have you made any recent changes?
RE: HTML module not updating after transfer from localhost to live server by chrisoc
Hey guys,Thanks for the replies.   All seems to be working fine now.  I had previously cleared the b...
RE: w2k8 r2 - dnn site visible locally but not from internet by guyperrin
thanx joe. i just kept slugging away at this one. finally, when i gave IIS_IUSRS Full Control, i w...
RE: HTML module not updating after transfer from localhost to live server by jncraig
Check to make sure that you adjusted your portalalias table to point to the live site. It's possibl...
RE: w2k8 r2 - dnn site visible locally but not from internet by jncraig
Check to make sure that DNS points the site's URL to the web directory.  Your host ought to be able ...
RE: user retrieve password by giving email by jncraig
That should work. As with most things like this, I would recommend that you test and verify this ...
RE: Creating a new user by jncraig
DotNetNuke uses the ASP.NET membership scheme. I haven't tested, but I am reasonably surethat the s...
RE: Email Verification by jncraig
Is this a question about Dynamic Forms? You can use Regular Expression validation to force the us...
RE: Issue 33 SQL updating page settings by jncraig
Can you describe the problem a bit more?
user retrieve password by giving email by raf948
I am using 4.8.0  and would like to have users retrieve password by giving their email ( as I unders...
RE: Change linkclick to document name by WinXnet
as far as I know, there is no way to not use linkclick other than to hard code the long url Selec...
RE: Skin missing banner and menu when ctl is used in the url by WinXnet
you're site appears to be down...
RE: DNN Live site not displaying by WinXnet
Is your site Properties in IIS > Documents > Enable default content page set to "Default.aspx"? E...
What version of DNN? Emerson ^_^
RE: Cross Portal Admins by WinXnet
Sorry for this post ^_^ My error - I got the password for the user wrong. Create user account ...
The menu is a module and it is set to publish on all pages. The HTML module is not set to publish t...
I have  situation where admins want to use the same login/password across multiple parent DNN portal...
RE: Issue 33 SQL updating page settings by pedrocapetillo
I have i similar problem and i am using DNN360 menu. Does anybody have information about that? Be...
Store module just refreshes page on "confirm order" by mike.hassinger
I have set up the store module with an Authorize.net account, set for authorize + capture. The check...
RE: logo token not functioning by WinXnet
I'm sure you've done this, but be sure you click on the "upload selected file" link under the Browse...
Is your menu a module as well? Is your banner HTML module set to "publish on all pages", or is it...
