Subject: Non Standard Port with DNN 5+
Adrian
16 Mar 2010 7:31 PM
Hello Some time back we started tinkering with DNN v5, however we couldn't get it to work when trying to deploy using a non-standard port (ie. not port 80) Were there any tricks involved to get this to work? Using DNN 4.9.5 on a non-standard port seems to work fine, without having to "do anything extra"
17 Mar 2010 10:10 AM
In web.config ... "set UsePortNumber to true to preserve the port number if you're using a port number other than 80 (the standard)"
You may also have to use the port number in the portalalias table -- my memory is inconsistent on this point.
Forums > DotNetNuke® > DotNetNuke® Questions > Non Standard Port with DNN 5+
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
