Subject: Home Page Login Question
BCRose
13 Mar 2010 11:40 AM
I would like to remove the 'LOGIN' text from the top right of my pages.   How can I do this?   I tried removing any reference to 'login' in the stylesheet editor but that didn't seem to do anything.
Any help would be appreciated
Monte
13 Mar 2010 11:43 AM
The LOGIN and REGISTER links are Skin Objects that are included in your skin file. The easiest way to remove them is to edit your skin file.
It is also possible that your skin wraps these objects in a named div tag. If that's the case, you can style that div for display:none to remove it without editing your skin file.
BCRose
13 Mar 2010 11:56 AM
Thanks for the quick reply.
Sorry for being a dummy but where do I edit a skin at? Or the style sheet for the skin?
14 Mar 2010 12:29 PM
Start with:
Then move on to some of the other skinning tutorials.
BCRose
14 Mar 2010 12:43 PM
Thanks Lee...I have been watching the videos. Lot's to learn here.
Forums > DotNetNuke® > DotNetNuke® Questions > Home Page Login Question
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
