Subject: Localizing Skins and css dynamically based on language selected
Sadabahar
09 Feb 2010 9:22 AM
Hi, I want to dynamically assign a skin and CSS based on the language selected. Different pages has different skins, and each skin has 2 copies, one for English and one for Arabic. I want that if a user has selected English language, English skin will be selected for a particular page and if Arabic language is selected, Arabic skin is assigned to the page? can any body help me out?
09 Feb 2010 4:15 PM
I think that you'll need to create a custom "skin switcher" that does this based on the selected language. I have not looked at doing anything like this, so I can't give specific advice.
Forums > DotNetNuke® > DotNetNuke® Questions > Localizing Skins and css dynamically based on language selected
Folder permissions by saintX
That will work.
