Subject: Recomended DNN version?
lolorn
09 Feb 2010 9:10 AM
What version of DNN would be recommended for creating a new site? Has DNN 5.2 turned out to be as stable and good as rumored? Thanks
09 Feb 2010 4:15 PM
Version 5.2.2 is just fine.
Forums > DotNetNuke® > DotNetNuke® Questions > Recomended DNN version?
That will work.
