Subject: Ealo Tab Localization help
Sadabahar
09 Feb 2010 1:38 AM
hi, I have installed Ealo Core Api and Ealo tab localization and ealo Menu provider. menu is working fine with the text provided for differnt languages but Title is not working? any body can help?
Forums > DotNetNuke® > DotNetNuke® Questions > Ealo Tab Localization help
RE: How to Create an Email Form with OWS - Issue 49 by CelesteT
Hi, Was also wondering if there was a way to incorporate ReCaptcha (www.recaptcha.net) into the emai...
Hi, Thanks for the great tutorial. I was wondering how I can hard code a "to" email address into th...
That will work.
