Subject: Customizing registration page
KA-NA
08 Feb 2010 8:32 AM
Hello, Is there any possibility to custom registration form from VS2008? I need to put list with second list (user must choose language and then choose from 1 to 10 how much he nows it). Is there any possibility to do this? And one more question. I would like to set i.e. phone as unique ID. Only one account with that the same value would be accepted in DNN. Is it possible to set one field as unique ID? Regards Marek
08 Feb 2010 8:37 AM
You can do this without any coding.  You will want to look at:
If you need more flexibility, a third-party (commercial) module might be helpful.  And these tutorials might be appropriate:
There are other modules, too.  Look at Snowcovered.
KA-NA
08 Feb 2010 11:33 AM
Thanks for an answer.
I saw creating with OWS and I'll try it tomorrow.
First three links doesn't give me a possibility to do, what I need. I explained maybe to simple...
I need to add three records to my register form. I thought, that maybe is possible to rearange some ascx file, that one record in database will be inserted from dropdownlist and textbox.
Choose first Language [language],[|] choose score [score]
Choose second Language [language],[|] choose score [score]
Choose third Language [language],[|] choose score [score]
Maybe I set all boxes in two columns and then try to arrange them, as they will looks like lines (sign [|])
Is it possible to make changes in registration by .NET? I'm MS Developer, but I didn't found where make it
08 Feb 2010 6:21 PM
You can add three fields to the user profile as you describe.  No coding is required.  Look at the Manage Profile Properties link on the User Accounts page.
You can, but I don't recommend, that you start rewriting the basic code of DotNetNuke.
KA-NA
09 Feb 2010 4:33 AM
Forums > DotNetNuke® > DotNetNuke® Questions > Customizing registration page
RE: Permissions Question by BCRose
Does that involve editing the source code? May not be too big of a challenge to you but that is som...
Is this fixed now?
RE: Permissions Question by jncraig
Well, thinking about it ... it would not be too big of a challenge to take the module, remove the fe...
Ummm...too bad. That seems like a no-brainer for this module.
I don't believe that's possible. I'd love to learn that I'm wrong.
Ok, Thanks for the info. I was able to make those changes, Now...I want this user to be able to ad...
In DotNetNuke 5.x, you have control of permissions on the Admin and Host pages. So, you can grant p...
Is it possible to give a user permission to add and delete users, change pw's etc. without giving th...
RE: daisy chain continuous loop of all the flash files by mlorence
I made a test html page in Dreamweaver and it works perfectly, just as it does on my desktop. I u...
Sorry about that. That was my test domain and I just switched it to the permanent....http://www.neb...
Strange behaviour when pressing login by pontus66
Hi,When pressing Login (Sign In) on one of my clients portals the adress for the homepage gets sort ...
RE: My site is down by proarch123
Thank you Lee Sykes
RE: daisy chain continuous loop of all the flash files by jncraig
I would imagine that each file includes a URL to other link to the next file. That works fine on yo...
RE: Install Skin Error Message by jncraig
Where did you get this skin? It seems to be missing a file, license.txt, that is a required element...
RE: domain name by aventhika123
Hi, for expected Domain name use this http://www.xnynz.com/ site ,here only i got my all sites doma...
RE: How to Create a Custom Login Module with OWS - Issue 52 by kana
I modified Your example with one thing - looking for enter key on password field. I added that in Re...
Install Skin Error Message by Captain Canary
Hi When trying to install a new skin via Extensions with DNN v 5.2.3 I get the following error m...
RE: OWS Query Template Results by VickySwift
Hi, In the end I achieved what I needed with IIF statments and ALTERNATE Pretty sure its not the...
RE: Login problem with other browsers than IE by kana
I added alert(); into onkeypress and now after I press enter on messagebox page is forwarding fine. ...
RE: OWS Query Template Results by kana
I don't know, that is possible, but I would try to use javascript in dteial template to build string...
DNN Creative Subscribe
