Subject: Plz Help. Page_Load_Exception
Zaid Khan
07 Feb 2010 10:31 PM
Hi, my website often takes me to the under-construction page. When I saw my eventlog table I found too many general_exception and application_shutting_down errors and also found some Page_Load_Exception. I don't have much experience of DNN but I believe that its Page_Load_Exception which indicates that my webpage was redirected to under-construction page. im giving the details of that page_load_exception. please help me find out what actually is causing this.
LogGUID: 2ad97492-3d30-4feb-a225-35f32e923e57
LogTypeKey: PAGE_LOAD_EXCEPTION
LogConfigID: 6
LogUserID:
LogUserName:
LogPortalID: 0
LogPortalName: LogCreateDate: 2/8/2010 12:48:40 AM
LogServerName: 5-RUSSELL
LogProperties: AssemblyVersion04.08.00PortalID0PortalNamePAF KIETUserID-1UserNameActiveTabID37ActiveTabNameSearch ResultsRawURL/SearchResults/tabid/37/Default.aspx?Search=MBA+TELECOM+MANAGEMENTAbsoluteURL/Default.aspxAbsoluteURLReferrerhttp://www.pafkiet.edu.pk/Academics/DegreeProgramsOverview/tabid/340/Default.aspxUserAgentMozilla/5.0 (Windows; U; Windows NT 6.1; en-US) AppleWebKit/532.5 (KHTML, like Gecko) Chrome/4.0.249.78 Safari/532.5DefaultDataProviderDotNetNuke.Data.SqlDataProvider, DotNetNuke.SqlDataProviderExceptionGUID9a48582f-758a-4d43-b307-8f7b203034e7InnerExceptionObject reference not set to an instance of an object.FileNameFileLineNumber0FileColumnNumber0MethodDotNetNuke.Services.Search.SearchDataStore.GetSearchResultsStackTraceMessageDotNetNuke.Services.Exceptions.PageLoadException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object. at DotNetNuke.Services.Search.SearchDataStore.GetSearchResults(Int32 PortalID, String Criteria) at DotNetNuke.Modules.SearchResults.SearchResults.BindData() in C:\inetpub\vhosts\pafkiet.edu.pk\httpdocs\Admin\Search\SearchResults.ascx.vb:line 74 at DotNetNuke.Modules.SearchResults.SearchResults.Page_Load(Object sender, EventArgs e) in C:\inetpub\vhosts\pafkiet.edu.pk\httpdocs\Admin\Search\SearchResults.ascx.vb:line 272 at System.Web.UI.Control.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) --- End of inner exception stack trace ---Source
LogNotificationPending:
08 Feb 2010 7:26 AM
That particular error seems to be related to the search indexer, a scheduled task that runs periodically.
The application shutting down messages aren't errors, but indicate that the website is being unloaded by IIS after a period of inactivity.
In my experience, occasional redirects to the Under Construction page can be related to database access problems.
Do your Under Construction issues relate to a particular page, or are they more general.
Zaid Khan
08 Feb 2010 10:16 PM
thanks alot for replying Sir,
Well.. my Under Construction Redirect issues are more general and they occur more when users are logged in.
Sometimes I get too many under construction page riderects and some times very few.
My SQL Server is remote from my Files Server. both servers are shared and have hunderds of databases. My Host is M6.net.
My DNN version is 4.8.0.0.
09 Feb 2010 6:11 AM
Can you provide a URL?
Zaid Khan
09 Feb 2010 8:42 AM
URL of My website is www.pafkiet.edu.pk
09 Feb 2010 4:22 PM
I did look at your site and did get one "under construction" page. Refreshing brought the correct page. I still think that this is an error that is related to a temporary failure to connect to the database.
Zaid Khan
10 Feb 2010 8:34 AM
Ok, so you mean to say that page riderct issue does not occur because of these general exceptions and page load exceptions. Also tell me what should I do. My hoster has too many MS SQL Databases on One Server. Should I change my hoster?
10 Feb 2010 11:06 AM
If database server loading really is the problem, and your host cannot do anything about it, then changing hosts or changing hosting plans is an option.
Forums > DotNetNuke® > DotNetNuke® Questions > Plz Help. Page_Load_Exception
The LOGIN and REGISTER links are Skin Objects that are included in your skin file. The easiest way ...
I would like to remove the 'LOGIN' text from the top right of my pages.   How can I do this?   I tri...
Yes, that is the one.
Thanks for the tip. I will let my programmer check it out. This is the module you're referring t...
RE: extending user accounts for membership by jncraig
Try these:User Accounts new features User Accounts and User Settings Enforcing Terms and Conditions ...
RE: DataSprings Dynamic Forms Demo #20 Question by jncraig
There are some nice examples on the Data Springs site.  The more complicated demos do require some s...
RE: Dynamic Forms Email From User/Pass by jncraig
If the SMTP server is configured so that it will not send email from arbitrary email addresses, I wo...
Glad that you got it solved.There is a free module available from Iowa Computer Gurus that automates...
RE: DataSprings Dynamic Forms Demo #20 Question by aggiedan97
Thanks for the feedback. I will let you know what I find and I have posted on the DS forum. So far ...
RE: ITextSharp by leesykes
Glad you got it sorted, what was the solution for anyone else searching for this problem?
RE: DataSprings Dynamic Forms Demo #20 Question by leesykes
Hello,This is not something I have explored yet, but as it happens I am going to be building a form ...
I am attempting to build an order form that subtotals a section that is based on the 'TotalByQuan&nb...
RE: Shared Same content in Sub portals/ Childportals by leesykes
Hello,Your other option is to use RSS feeds for sharing content. Setup a module on your main site su...
