Subject: DNN 5.2.0 and special characters
saintX
31 Dec 2009 3:07 AM
Hello, DNN 5.2.0 can not display some characters linke Ü or Ö. I know that this is a known bug of this version. Is there meanwhile any solution for this issue? Thanks
31 Dec 2009 9:06 AM
Does 5.2.1 address the problem?
saintX
31 Dec 2009 5:11 PM
I do not know about 5.2.1 Joe. If I don't find a solution for 5.2.0 then I will have to upgrade 3 websites :-( Thanks
31 Dec 2009 5:38 PM
Do you know if the problem was logged in the DotNetNuke bug tracker?  If so, do you know the number?  We can check to see if the problem has been fixed.
saintX
03 Jan 2010 9:25 AM
As far as I have informed myself and also tried out: In the settings of the module the cache time should be set to zero. It works, but I worry about possible later upgrades, the people say that 5.2.1 has also some bugs, I still don't know which bugs? Until the 5.2.2 is been released and proofed may take a long time, will I have to change the chache again after a possible upgrade?
03 Jan 2010 10:43 AM
You can look at support.dotnetnuke.com if you want to find bugs or other issues in DotNetNuke.  The list can be searched by version.
Forums > DotNetNuke® > DotNetNuke® Questions > DNN 5.2.0 and special characters
RE: DataSprings Dynamic Forms Demo #20 Question by aggiedan97
Thanks for the feedback. I will let you know what I find and I have posted on the DS forum. So far ...
RE: ITextSharp by leesykes
Glad you got it sorted, what was the solution for anyone else searching for this problem?
RE: DataSprings Dynamic Forms Demo #20 Question by leesykes
Hello,This is not something I have explored yet, but as it happens I am going to be building a form ...
I am attempting to build an order form that subtotals a section that is based on the 'TotalByQuan&nb...
RE: Shared Same content in Sub portals/ Childportals by leesykes
Hello,Your other option is to use RSS feeds for sharing content. Setup a module on your main site su...
RE: Should I be able to use a plain submit button in my module? by DiscoStu1975
Hi I used an ASP:button control originally and that produced exactly the same error with JS disa...
Hmmm, I think that I have seen something like this before, but I'm having trouble remembering the ex...
RE: Shared Same content in Sub portals/ Childportals by jncraig
There are modules available that will permit you to share pages, modules and user among portals in a...
RE: Should I be able to use a plain submit button in my module? by jncraig
Using a form submit button won't work. If you use an ASP:button control that will work as clicking ...
Hi Joseph Thanks for the response. I am using an html input of type submit, yes. When you say a l...
Are you using a form submit button? Try just just using a link and see if that works.
RE: Removing the filed by jncraig
I don't know an easy way to do that, short of editing the ascs file that displays that information. ...
RE: ITextSharp by jumatthey
Problem solved.
Removing the filed by kaustav_kar
Hi,I want to remove the option Display Name from this page. http://whydiet-com.stagemefaster.com/hom...
I have developed a module that is basically a simple data capture form. As I need the form to work w...
RE: Links by rajanijadhav
I have another question,in paypal integration for payment i have used [script removed]
Shared Same content in Sub portals/ Childportals by carlliw
Hello,I have a DNN parent portal and about 35 child/subportals. There are about 5 pages in all 35 c...
DNN Creative Subscribe
