Subject: send user properties by forms
polyvan
31 Dec 2009 2:19 AM
Hello everyone and happy holidays.
I'm new in this forum and i'm french, so i'll try to make my question as clear and simple as possible.
I want to know how can i get to [User:Username] or any other token send by mail via a form.
I explain.
I've got a user (a company) in which i can have multiple users with different emails.
In a page i've made a form in which to actual user can add a new email on his account.
I know how to send forms and thus get the email string that he wrote, but how can i get send with  this email those properties :
Username equivalent to the token [User:Username], but also the value of the role of this account, if it's registered, administrator or anything else ?
I'm unable to find something to deal with on the web.
So please help me.
Thank you and best regards for all.
31 Dec 2009 9:09 AM
You should be able to do this with Dynamic Forms.  Here are some tutorials:
You can also download the extensive user manual from their website.
polyvan
04 Jan 2010 2:21 AM
Happy new year and many thanks,
i'll try this.
Best regards.
Forums > DotNetNuke® > DotNetNuke® Questions > send user properties by forms
How to do links? by Guy..L
How to close a website while you are working on it by mcmanta
The LOGIN and REGISTER links are Skin Objects that are included in your skin file. The easiest way ...
I would like to remove the 'LOGIN' text from the top right of my pages.   How can I do this?   I tri...
Yes, that is the one.
Thanks for the tip. I will let my programmer check it out. This is the module you're referring t...
RE: extending user accounts for membership by jncraig
Try these:User Accounts new features User Accounts and User Settings Enforcing Terms and Conditions ...
RE: DataSprings Dynamic Forms Demo #20 Question by jncraig
There are some nice examples on the Data Springs site.  The more complicated demos do require some s...
RE: Dynamic Forms Email From User/Pass by jncraig
If the SMTP server is configured so that it will not send email from arbitrary email addresses, I wo...
Glad that you got it solved.There is a free module available from Iowa Computer Gurus that automates...
