Subject: UnderConstruction Message
Andrew Campbell
25 Dec 2009 5:14 PM
Hi All, (Merry Xmas) I had DNN 5.2.1 installed on a host service (dotnetpark) as I was having problems with 5.0.0. It is a new website and so I'm lucky as no content has been added. Last night I uploaded a couple of free skins. This morning when I go to access my site I go to the UnderConstruction page message. I have no idea of how I can get around this message, I can't even login to access Host account. Does anyone have any ideas? Thanks. Andrew
25 Dec 2009 6:06 PM
It the site was working after you installed the skins but is not working now, I might suspect the connection to the database. Have your host check that, or check it yourself if they provide database tools.
If you have access to the web directory, you could delete the directories that hold the new skins. That will tell you if the skins are causing the problem.
Andrew Campbell
25 Dec 2009 8:55 PM
Hi Joe, Yes the site was working fine after I installed the skins. I even set the site back to the default skin before logging out. How do I check the database? I also have FTP access to my site. Andrew
25 Dec 2009 8:57 PM
Do you have access to SQL Server Management Studio, or some other tool that you can use to connect to the database? I'd try those, using the username and password that appears in your web.config file.
And ... I'd ask for tech support from your host.
Andrew Campbell
25 Dec 2009 9:39 PM
I have used my host's online SQL tool to access the database using the username and password from my web.config file.
I am able to connect to it OK. I don't have SQL SMS so I can't test that.
I have contacted tech support and I am waiting for their reply.
Forums > DotNetNuke® > DotNetNuke® Questions > UnderConstruction Message
RE: Permissions Question by BCRose
Does that involve editing the source code? May not be too big of a challenge to you but that is som...
Is this fixed now?
RE: Permissions Question by jncraig
Well, thinking about it ... it would not be too big of a challenge to take the module, remove the fe...
Ummm...too bad. That seems like a no-brainer for this module.
I don't believe that's possible. I'd love to learn that I'm wrong.
Ok, Thanks for the info. I was able to make those changes, Now...I want this user to be able to ad...
In DotNetNuke 5.x, you have control of permissions on the Admin and Host pages. So, you can grant p...
Is it possible to give a user permission to add and delete users, change pw's etc. without giving th...
RE: daisy chain continuous loop of all the flash files by mlorence
I made a test html page in Dreamweaver and it works perfectly, just as it does on my desktop. I u...
Sorry about that. That was my test domain and I just switched it to the permanent....http://www.neb...
Strange behaviour when pressing login by pontus66
Hi,When pressing Login (Sign In) on one of my clients portals the adress for the homepage gets sort ...
RE: My site is down by proarch123
Thank you Lee Sykes
RE: daisy chain continuous loop of all the flash files by jncraig
I would imagine that each file includes a URL to other link to the next file. That works fine on yo...
RE: Install Skin Error Message by jncraig
Where did you get this skin? It seems to be missing a file, license.txt, that is a required element...
RE: domain name by aventhika123
Hi, for expected Domain name use this http://www.xnynz.com/ site ,here only i got my all sites doma...
RE: How to Create a Custom Login Module with OWS - Issue 52 by kana
I modified Your example with one thing - looking for enter key on password field. I added that in Re...
Install Skin Error Message by Captain Canary
Hi When trying to install a new skin via Extensions with DNN v 5.2.3 I get the following error m...
RE: OWS Query Template Results by VickySwift
Hi, In the end I achieved what I needed with IIF statments and ALTERNATE Pretty sure its not the...
RE: Login problem with other browsers than IE by kana
I added alert(); into onkeypress and now after I press enter on messagebox page is forwarding fine. ...
RE: OWS Query Template Results by kana
I don't know, that is possible, but I would try to use javascript in dteial template to build string...
