Subject: Object reference error: UpdateTabModuleSetting(Int32 TabModuleId, String SettingName, String SettingValue)
majd_wadi
24 Dec 2009 3:46 AM
hay all,
i have the latest dnn version, i've just upgraded it.
anyway, i inistalled Form & List module on my portal and imported some data into it, but each time i try to edit a column or add a new column i get the below error:
DotNetNuke.Services.Exceptions.ModuleLoadException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object. at DotNetNuke.Entities.Modules.ModuleController.UpdateTabModuleSetting(Int32 TabModuleId, String SettingName, String SettingValue) at DotNetNuke.Modules.UserDefinedTable.Configuration.SaveSettings(Object sender) --- End of inner exception stack trace ---
i uninstalled it and re inistalled it many time, and the error still appears for only this module.
what would be the cause ?
please advice .
thank u all.
24 Dec 2009 8:52 AM
Versions, please.
Which version of DotNetNuke do you have after the upgrade?
Which version of the Form and List module?
You might get more focussed help on the DotNetNuke forums from the Form and List module developers.
majd_wadi
24 Dec 2009 9:09 AM
Thanx for your reply.
the dnn version is 05.02.01
and the module's version is 05.00.03.
i made a posting on DNN forums but still no replies.
Forums > DotNetNuke® > DotNetNuke® Questions > Object reference error: UpdateTabModuleSetting(Int32 TabModuleId, String SettingName, String SettingValue)
RE: PayFlow Link by johnmurphy
Hi murphydolores, I am using iHost. iHost.Net supports PayFlow Link and its easy to configure. T...
RE: Background Music by cyborama
Hello Kyle I can't think of any modules that could do this though that doesn't mean they are not out...
Hello Joe thanks for the quick reply, If you read down my thread fully you will see I had already...
DNN Creative Subscribe
