Subject: Problem with UI
Rami
19 Dec 2009 6:44 AM
i'm using dnn 4.9 and facing some problems in controlling UI, the most disturbing ones are 1. aligning and direction I'm using RTL culture. 2. controlling the dimensions of my modules in the page. is there a tool or module that I can use to control the locations and dimensions of my modules? is there any article or video the direct me how to control the direction and aligning of my skin? plz I need help thanks.
19 Dec 2009 9:43 PM
I recommend that you visit the Localize It Forum at DotNetNuke.com form questions about RTL websites.  You'll find more people there with this interest.
For skin issues, start with the tutorials on this site on that topic.  There is a long list.  I don't recall anything that deals in detail with RTL issues, but every thing else is there.
21 Dec 2009 2:31 AM
There is also an interview here that may be of interest covering RTL:
How did they build …?
Looking at website design and languages with Laurence Neville
That will work.
