Subject: Profile display
Bart A Zoni
18 Dec 2009 10:02 PM
I went through a September 2006 set of tutorials on How to manage profile properties in user accounts. I see that my 5.1.4 version did away with some of the ascx module editing which was great. However, the way that the profile appears to the user looks a lot different in the older version used in the tutorial than it does now. I liked the categorized display rather than a long list of properties that now show up. Is the difference in the display due to different skins used then and now? How can I get the old look back?
19 Dec 2009 5:14 AM
I actually hadn't noticed this until seeing your question. I don't see any way to change the display either.
Qonsalt
17 Feb 2010 1:56 PM
Hi. Any update on this issue?
I'm using DNN 5.2.2 and have been desperately searching for profile field categorization functionality from the new version. I also miss the categorization that was present on the old DNN Creative tutorial videos and DNN versions. Do you think that this is a bug in the current release or have they really ripped out the whole thing on purpose?
Any ideas?
17 Feb 2010 2:27 PM
I've had a look at this in DNN5.x and can't see a way of enabling the categorization feature, I even tried adding a profile property with DataType of Unknown to see if it would display it as a label, but it just doesn't display the field.
Not sure if this is a bug or if they have removed it on purpose. Thanks,
Qonsalt
17 Feb 2010 2:37 PM
Hi and thanks for your immediate response. Just to inform that I added this as a new bug to their bug reporting system. Let's see what happens.
17 Feb 2010 2:39 PM
Thanks for the info, let us know if you get a response,
That will work.
