Subject: can not delete a text/html module
tiktacs
08 Dec 2009 9:37 PM
I have created a child portal found at http://site121.mysite4now.com/colwar/blank/
My issue is this ...
When I add a new page a Text/Html module titled CONTACT US is added to the new page.
I don't want the CONTACT US module but I can't find where to delete it.  I assume it must be on a page in the site somewhere with DISPLAY MODULE ON ALL PAGES checked.  However I just can't find it, to delete it.
How can I get rid of this module?
Thank you so much for you help.
09 Dec 2009 1:59 AM
if you have access to your SQL tables you can find out which module is causing this problem. Have a look at this tutorial for the information on how to do is:
Working with Shadow / Copied Modules and SQL in DotNetNuke
tiktacs
10 Dec 2009 2:40 AM
Thank you very much.
Forums > DotNetNuke® > DotNetNuke® Questions > can not delete a text/html module
RE: Server Error in '/' Application. by michellb
Here is the entire text on the page: Server Error in '/' Application. Runtime Error Descrip...
No, I still don't have a solution for this
