Subject: Apostraphes showing up as Question marks
Patrick Ryan
07 Dec 2009 2:43 PM
This is driving me insane.
On my site, the apostraphes keep showing up as "?"
If I edit content in the module.. they are fine.. Nothing special in the code.. just straight text.. Then I click save and it's fine for a while.. Then a day later or so, they are all question marks again. It's driving me insane!!
Any help would be greatly appreciated.
Patrick
09 Dec 2009 2:41 AM
that sounds really strange, what is in the source code for a page when it has changed to to ? do they display as '
Can you give us a URL to an example page that is displaying ?
Patrick Ryan
09 Dec 2009 9:17 AM
Well, I think I figured out the problem but I still don't fully understand. The Text/HTML modules .. I copied content from Adobe InDesign and pasted it into the modules. Even looking in source mode I see NO formatting issues what-so-ever.
So I don't know how hidden characters could have "snuck" in.
To fix the problem I deleted all of the HTML/TXT modules, and created new ones and typed everything in again without copy/pasting from InDesign.
I don't understand this problem fully, but I wish that I did in case it comes back!
So I can't show a URL either since I fixed the problem..
This is still an issue though if you g uys have any ideas as to a fix.
09 Dec 2009 9:24 AM
If you are copying and pasting, try using the copy as notepad button in the FCKEditor - this strips out everything except the text - very useful if pasting from word docs, so it should also work for InDesign
11 Dec 2009 9:02 PM
I wonder if this issue is related.
12 Dec 2009 2:05 AM
Interesting, thanks for info Joe
12 Dec 2009 2:20 PM
I just applied Sebastian's fix to a 5.2.0 site that showed copyright symbols a question marks. After running the SQL script, clear the cache and restart the application on the Host Settings page.
Patrick Ryan
14 Dec 2009 7:23 AM
So is this the issue then? It seems? Interesting.
Forums > DotNetNuke® > DotNetNuke® Questions > Apostraphes showing up as Question marks
Folder permissions by saintX
That will work.
