Subject: Replacing FCK Editor
h2x
06 Dec 2009 10:11 PM
I am wondering if anyone has any recommendations about replacing the FCK editor? When I first started using DNN a few years ago, I customized the editor for my sites and this was an okay solution. On my most recent project I purchased CuteSoft's .net editor for DNN. Although I really like this editor, I was not at all happy with their tech support/customer service and am starting to have real doubts about the legitimacy of the company. Regardless, I am not starting a new project and wonder if I should just costumize the FCK editor again or purchase another solution?
Thanks so much!
09 Dec 2009 3:18 AM
if it was a few years ago when you customise the FCK editor, you may find that the latest version of the FCK editor is more compatible and you do not need as much customisation.
Your other option would be to look at Telerik
Forums > DotNetNuke® > DotNetNuke® Questions > Replacing FCK Editor
Module Advanced Setting by booth
I need to understand the operation of the “Display Module On All Pages ” control on the setting page...
Efficient Contacts Manager by etadmin
Currently I'm using the Forms and List module, it has about 1500 contacts and 40-50 fields per conta...
RE: How to do links? by leesykes
I think the easiest way to set this up would be to use the default NAV Menu that comes with DNN. It ...
RE: DataSprings / Aweber by leesykes
Yes you probably used an IFrame over a HTML file which included the form, IFrame still exists.Here i...
RE: ITextSharp by leesykes
thanks for the info
and for the Aweber section you should be able to setup a Form completion event on that form which se...
You shouldn't have to delete and recreate. The internal (to DotNetNuke) addressing is handled by th...
I think I have figured out the answer myself. In my host is something called A Records. This is equ...
RE: Saving site settings error by jncraig
When you say that you "published" the site, do you mean published from within Visual Studio?I'd reco...
RE: Regular Expression by jncraig
Google for "Regular Expression Library" and search around. You should be able to find something tha...
RE: Change Registration Redirect? by jncraig
Dynamic Registration will permit you to use a "redirect after login" page.
RE: Removing View and Edit Buttons by jncraig
Most likely, the View and Edit buttons are there because either the page or a module on it has edit ...
RE: Removing View and Edit Buttons by jumatthey
o.O ... weird. This should only display if you are logged on as admin or host.
RE: Removing View and Edit Buttons by mikehj
I was able to remove the register in admin settings and I had already gone into the skins file and m...
Can you post a screeshot of what you are refering to more precisely ? Thanks. I personnaly remove...
Regular Expression by jumatthey
Hey all.I need to find out a regular expression for a DotNetNuke module I am building.This is my ASP...
RE: ITextSharp by jumatthey
The key line was this one : PdfWriter.GetInstance(document, new FileStream(HttpContext.Current.Se...
I have removed the Register and Login controls from the default page. I still have the Edit and Vie...
Saving site settings error by directaccess
Hey folks, Recently started looking at DNN. And did some nice tests out of VisualStudio using the...
Then again, I have a problem leaving things too simple. I will link to Aweber, most likely u...
