Subject: Restricting User Profile Settings
Chris
06 Dec 2009 8:34 PM
Does anyone know if there is a way to restrict Users from changing some of the their User Profile Settings? I've added some custom fields that I want to assign members of a Security Group in charge of changing these User settings because they require proof, but I want the User to be able to verify that the dates are correct.
09 Dec 2009 3:23 AM
I'm not sure how you would do this with the core registration, however you may be able to achieve this using modules such as datasprings dynamic series, I would contact their support and see if they have a suggestion on how it can be configured:
http://www.datasprings.com/Products/DNNModules/DynamicRegistration.aspx
Forums > DotNetNuke® > DotNetNuke® Questions > Restricting User Profile Settings
RE: How to Create an Email Form with OWS - Issue 49 by CelesteT
Hi, Was also wondering if there was a way to incorporate ReCaptcha (www.recaptcha.net) into the emai...
Hi, Thanks for the great tutorial. I was wondering how I can hard code a "to" email address into th...
That will work.
