Subject: Does this work with Aweber?
Nazarene Israel
05 Dec 2009 8:01 PM
http://www.nerdymusings.com/LPMTool.asp?TOOL=AWeberDNN Does this work with Aweber?
05 Dec 2009 8:04 PM
The website says that it does. I've never used it.
James H. Byrd
06 Dec 2009 10:03 AM
Yes, the tool was designed specifically for AWeber. The site has two articles that relate to it:
The "Posting to an Off-Site Page in DotNetNuke" article explains how the tool works:
http://www.nerdymusings.com/LPMArticle.asp?ID=20
The "Embedding Forms in an ASP.NET Web Page" explains the theory behind the process and shows how you can apply it to any situation where you need to post a form to a web site hosted elsewhere (e.g. for PayPal buttons).
http://www.nerdymusings.com/LPMArticle.asp?ID=27
If you still have questions or need additional help, please post it through the contact page on the Nerdy Musings site so I'll be sure to get it. I only saw your query here because of a Google Alert.
James Byrd
Contributing Editor
NerdyMusings.com
Forums > DotNetNuke® > DotNetNuke® Questions > Does this work with Aweber?
Glad it's working!
Firefox SWF file by ce221
PayFlow Link by murphydolores
RE: Send email with Dynamic Forms Results by jesp17
Hi Lee,I've asked DataSprings if there is a way to solve my problem (wish). Here is a reaction:I don...
Background Music by kparker
Do you know of any module that I can use to play background music on a single page?  Or do you have ...
DNN Creative Subscribe
