Subject: Add content with other role than administrator
QDelft
02 Dec 2009 7:51 AM
Hello Everyone,
As said in the subject I am trying to get users who aren't in the administrator role to add content to a page. I have been searching for a while now and all I can find is explanations for users for how to edit content but not how to add content.
Could somebody point me in the right directions? Thanks in advance
02 Dec 2009 9:11 AM
Do you want others to be able to add modules to a page? If so, you have to give them page edit permissions.
QDelft
02 Dec 2009 9:25 AM
Posted By Joseph Craig on 02 Dec 2009 9:11 AM
Yes that is what I would like to do. I gave this user role page edit permissions (Page > settings > Permission > Edit Page is checked for this Role).
When I logon with a user in this Role, I am able to edit the page. But when I want to "Add New module" the Module dropdownlistbox doesn't contain any modules.
Am I missing a permission setting which enables this dropdownlistbox to be filled with modules?
I added a screenshot with the empty dropdownlistbox
PS. thx for replying.
03 Dec 2009 4:32 PM
Sebastian Leupold answered a similar question over on the DotNetNuke forums. You need to go to Admin :: Extensions, edit the module, and grant "Publish" permissions for the module. Once you get there it's easy as the section is labelled "Deploy Module" or very similar wording.
QDelft
07 Dec 2009 1:31 AM
Yes, that was the missing factor. Thanks for the help!
I will keep that in mind, when I have another question to look there as well.
Forums > DotNetNuke® > DotNetNuke® Questions > Add content with other role than administrator
PayFlow Link by murphydolores
RE: Send email with Dynamic Forms Results by jesp17
Hi Lee,I've asked DataSprings if there is a way to solve my problem (wish). Here is a reaction:I don...
Background Music by kparker
Do you know of any module that I can use to play background music on a single page?  Or do you have ...
I did this several years ago, so I think that what I found must have been in the "Professional DotNe...
