Subject: Custom 404 error message for ASPX
Chip
01 Dec 2009 8:52 PM
Does anyone know how I can display a custom error message for an HTTP 404 error associated with an .aspx page?  If I type http://mydomain.com/an-incorrect-page.aspx I get the standard error page.  I would like to do one of two things:
1. have any incorrect page redirect to mydomain.com/home.aspx or if this is not possible/practical
2. have a custom .aspx page that they see.
I know how to customize the html error messages, but not these.
Thank you!
Chip
BCRose
02 Jan 2010 1:16 PM
Bump
I am looking for information on this as well.
02 Jan 2010 6:31 PM
I found one solution here.  Google for others.
Forums > DotNetNuke® > DotNetNuke® Questions > Custom 404 error message for ASPX
That will work.
RE: PayFlow Link by johnmurphy
Hi murphydolores, I am using iHost. iHost.Net supports PayFlow Link and its easy to configure. T...
RE: Background Music by cyborama
Hello Kyle I can't think of any modules that could do this though that doesn't mean they are not out...
Hello Joe thanks for the quick reply, If you read down my thread fully you will see I had already...
