Nsync DNN Creative Magazine Subscriber
 Nuke Newbie Posts:1
| 30 Nov 2009 8:09 AM |
| Wondering which edition of SQL 2008 is suitable to work with DotNetNuke for my company's website. I notice there's is Web Edition, will that suffice? |
Joseph Craig DNN Creative Staff
 Nuke Master V Posts:5331
AlexDe DNN Creative Magazine Subscriber
 Nuker Posts:14
| 03 Jan 2010 12:50 PM |
| I had followed the video tutorial for installation of DNN to the local PC with Win XP Home edition. The MVW has reported successful DNN site installation . The next address has been assigned by the system is "http://localhost:3695/DNN_5_2_Test2/Default.aspx". The site started to work, but after some minutes it has fallen down and I can not reconnect it by any http address. The message is: "The webpage at http://www.localhost/ might be temporarily down or it may have moved permanently to a new web address". |
| 03 Jan 2010 12:53 PM |
Did you make any changes after which the site quit working?
 Nuker Posts:14
| 03 Jan 2010 8:55 PM |
| No, I did not. I've repeat DNN installation treetimes, and the results are same: after the short time the sites are down. |
| 03 Jan 2010 9:37 PM |
Posted By AlexDe on 03 Jan 2010 12:50 PM
"The webpage at http://www.localhost/ might be temporarily down or it may have moved permanently to a new web address". The site is installed at http://localhost ...
Your message says that the site at http://www.localhost ... might be down.
http://localhost and http://www.localhost are NOT the same address. "localhost" is an alias for a web server on your local computer. "www.localhost" is not and is not defined. Try browsing to the localhost address without the www and see if that works.
 Nuker Posts:14
| 04 Jan 2010 10:51 AM |
Thank you for the remark. Unfortunatelly the replay is same "The webpage at http://localhost/ might be temporarily down or it may have moved permanently to a new web address". I had tried three times. During the installation the system define the next addresses: http://localhost:3032/DNN5_2_Test/Default.aspx; http://localhost:3695/DNN_5_2_Test2/Default.aspxhttp://localhost:2024/DNNtest3/Login.aspx?ReturnUrl=%2fDNNtest3%2fDefault.aspx. All of them works for the short time (gave me chance to change the admin password sometimes, but not more). I tried the IE8 and Google Chrome browsers, I had switched off the Norton 360 Premier ,but nothing works. |
| 04 Jan 2010 10:55 AM |
What is the story with the port numbers? Are you actually running this in Visual Web Developer and not as an IIS website? If so, then you'll need to restart VWD.
I guess I need some additional details regarding how you are installing and running DotNetNuke.
 Nuker Posts:14
| 05 Jan 2010 11:25 AM |
I'm running it in Microsoft Visual Studio 2008. The IIS is not installed on the Win XP Home additon. Detailed information on VS is below: Version 9.0.30729.1 SP Microsoft .NET Framework Version 3.5 SP1 Installed Edition: WD Express Microsoft Silverlight Projects 2008 91911-152-0000077-60631 Microsoft Silverlight Projects 2008 Version 9.0.30730.126 Microsoft Visual Web Developer 2008 91911-152-0000077-60631 Microsoft Visual Web Developer 2008 |
 Nuker Posts:14
| 05 Jan 2010 11:31 AM |
Hello Joseph, After restarting the server, I've repeated the site building and installation process again. The results are same. 1. The building process is successful. 2. The installation process is successful. 3. The assigner adress is: http://localhost:1061/DNNtest6/Default.aspx 4. The result of connection to the http://localhost/ is "This webpage is not available.The webpage at http://localhost/ might be temporarily down or it may have moved permanently to a new web address." 5. The result of connection to the http://localhost:1061/DNNtest6/Default.aspx is "Oops! This link appears to be broken." I would be happy to provide the logs of the building and installation processes if you give me the appropriate mail address. Thank you for support, Alexander |
| 05 Jan 2010 11:35 AM |
Since you are running inside of VWD, you should be aware (if you aren't already) that the port number gets reassigned everytime you restart the internal webserver. So, if you are getting this error after refreshing an existing page, you could be using the wrong URL. Right click on the system tray icon for the webserver to identify the URL to use.
| 05 Jan 2010 11:45 AM |
What do you mean by #2, installation? Are you doing a complete reinstall after every build?
 Nuker Posts:14
| 05 Jan 2010 3:16 PM |
Yes, for every try I : 1. Create a new subfolder, like С://DNN/Test6 2. Unzip the Comunity edition to the subfolder. 3. Build site with VWD. 4. Complete installation throw the IE8. Above mentioned way is recommended in the video tutorial "Installation DNN 4.5 on the Windows XP home edition". Everything works OK at start, but site became lost every time. |
| 05 Jan 2010 3:47 PM |
You shouldn't have to do the reinstall every time. But, I'm not understanding what is going wrong for you.
 Nuker Posts:14
| 05 Jan 2010 4:38 PM |
| Could the intsllation logs help in the problem solving? |
| 05 Jan 2010 5:33 PM |
You could attach the log to a post, and I'll take a look. Since the installation seems to be sucessful, I don't think that will help, but let's try it.
 Nuker Posts:14
| 05 Jan 2010 6:27 PM |
Yes. There's nothing there that looks wrong.
What happens if you stop VWD and simple rebuild? Do you get the site, or do you get returned to the Install Wizard?
