Subject: How to put DotNetNuke local site live?
ddk24
19 Nov 2009 9:54 AM
Hi all, I was wondering what possibilities I have to put a local DNN-test site live. - A provider which has DNN already prepared? - A local machine that I put on the WWW? please share your experience. Thanks. Danny
10 Dec 2009 1:57 PM
You may want to view:
How to transfer a localhost DotNetNuke installation to a live website
Find and Replace SQL queries for DotNetNuke
(To fix problems after transferring a localhost database to a live website and other useful functions)
Forums > DotNetNuke® > DotNetNuke® Questions > How to put DotNetNuke local site live?
The LOGIN and REGISTER links are Skin Objects that are included in your skin file. The easiest way ...
I would like to remove the 'LOGIN' text from the top right of my pages.   How can I do this?   I tri...
Yes, that is the one.
Thanks for the tip. I will let my programmer check it out. This is the module you're referring t...
RE: extending user accounts for membership by jncraig
Try these:User Accounts new features User Accounts and User Settings Enforcing Terms and Conditions ...
RE: DataSprings Dynamic Forms Demo #20 Question by jncraig
There are some nice examples on the Data Springs site.  The more complicated demos do require some s...
RE: Dynamic Forms Email From User/Pass by jncraig
If the SMTP server is configured so that it will not send email from arbitrary email addresses, I wo...
Glad that you got it solved.There is a free module available from Iowa Computer Gurus that automates...
RE: DataSprings Dynamic Forms Demo #20 Question by aggiedan97
Thanks for the feedback. I will let you know what I find and I have posted on the DS forum. So far ...
RE: ITextSharp by leesykes
Glad you got it sorted, what was the solution for anyone else searching for this problem?
RE: DataSprings Dynamic Forms Demo #20 Question by leesykes
Hello,This is not something I have explored yet, but as it happens I am going to be building a form ...
I am attempting to build an order form that subtotals a section that is based on the 'TotalByQuan&nb...
RE: Shared Same content in Sub portals/ Childportals by leesykes
Hello,Your other option is to use RSS feeds for sharing content. Setup a module on your main site su...
