Subject: Encoding a hebrew page
Alejandro Kuzner
12 Jul 2009 3:05 PM
Hi, i have a dotnetnuke 4.94 application and i have problems with some modules to show hebrew. Where I can change the encoding of the dotnetnuke application?
13 Jul 2009 1:12 PM
Do some modules display hebrew and others do not?
You may find that some modules do not have localization enabled, you can check this however by going to the admin menu / languages
Click on language editor
Expand Local Resources / Desktop Modules
Inside there you will see the language files for each module.
Forums > DotNetNuke® > DotNetNuke® Questions > Encoding a hebrew page
Folder permissions by saintX
That will work.
